HELP! exhaust still leaking
My new diamond eye 4" straight pipe is still leaking. I put it in last weekend and knew about the leaks, I figured I would drive it for a week or so, come back and make some adjustments and re-tighten everything. I just made the adjustments and installed my new v-clamp on the turbo as I over tightened the last one, but i still have leaks at almost every joint including the turbo/downpipe. I know some will probably tell me to have it welded, but is there anything I might be missing before I get to that point? I am going to be traveling home in about a week and a half (500 mile drive), will it be ok to drive with these leaks? How important are they to get fixed? I have heard about getting carbon monoxide poisoning from exhaust seeping into the cab, is this true?
Also, when im driving and hit the brakes, the engine gets louder within the cab, I feel like that might have to do with the leak at the turbo, but I'm not sure.
Edit: I don't know how bad the leak around the turbo is, I have felt air flowing around it but not sure if it's all coming from the turbo or elsewhere Sent from AutoGuide.com Free App Last edited by mathewsz7; 02-21-2013 at 03:33 PM. |
If you are not happy with the seal you get after tightening down the U clamps you could always try a stepped band clamp. The only times I've had similar is when the U clamp was the wrong size or I didn't torque it down enough.
Almost sounds like your down pipe is hitting the cab. Mine did similar when applying peddle in reverse, until I readjusted it. Leak at the turbo /dp connection may be related to bad fit due to dp hitting cab. |
I thought it had enough space, but I can check again. Also, what about driving with it like this?
Sent from AutoGuide.com Free App |
Youre probably feeling air off the cooling fan but if you want to test if your DP is leaking at the turbo exhaust flange, fill a spray bottle w soapy water and hit it at the joint. I'd probably do this when its cold to prevent evaporation. The soap will bubble up at the point of the leak.
