trans cooler install - Ford Powerstroke Diesel Forum
Old 08-22-2006, 07:30 PM
new guy needs a little help. looking at intalling a larger trans cooler in place of the stock cooler, is the factory cooler after the rad cooler - direction of flow? 95 powerstroke
Old 08-22-2006, 07:41 PM
flow should come out of the trans, through the rad cooler, then to the factory external cooler, then back to the trans....
Old 08-22-2006, 07:42 PM
Power Strokeaholic
HA!! i shoulda held on a second. i just pm'd you marc about what i did. oops.
Old 08-22-2006, 07:46 PM
i answered your PM bill....the proper way to install a bigger cooler would be this....
Trans to rad to cooler1 to cooler2 back to trans
doesnt matter which external cooler is where (cooler1 and cooler2 are interchangable) but the radiator cooler should be the first to get flow
the rearward line on the trans should be the return line....
Old 08-22-2006, 07:59 PM
thanks for the speedy help, i just wasn't shure what was done at the factory
i really didn't to check the flow by running the engine,
Old 08-23-2006, 02:11 PM
lukecline
Guest
Posts: n/a
fwiw i just use a huge torqueshift cooler and did away with the factory rad cooler. Empty my temps never get higher than 150 and loaded rarely cross 165.
luke
Old 08-23-2006, 04:46 PM
Power Strokeaholic
thats what i put in luke but still ran it thru the radiator. i think i have it going thru the cooler then the radiator because it's not running as cool as you are
