FS2500 and electric fuel
Sorry if this should be in the performance discussion, but I figured it was more general. I have a new truck with Swamps electric fuel and it has an oil pressure switch located just to the side of the oil filter. I also have an FS2500 that I'm going to install. problem is, that the oil line to the filter needs to use the same port as the oil switch. The return line is no problem. Think I can use a T to hook the oil press switch to or will the switch not get the pressure it needs to let the fuel system run? I will figure out how to put some pics up if I can. Thanks in advance for any help you gurus can give!
Use a brass tee to plumb them all in. That's what I did with my set up
Awesome, thanks a lot. I knew that someone on here would know the answer. Much appreciated sir
