203 thermostat vs stock
what is the ups and downs i live in southeastern pa with mild winters and not reall hot summers ive noticed lately the temp gauge struggles to reach the n mark with 122k im figuring its still th oem stat and am just going to change it which one would be the better choice
Use this housing...
http://www.dieselsite.com/oemthermos...ordpsd73l.aspx With this stat... http://www.dieselsite.com/dieselsite203thermostat.aspx Your truck will love you for it... Powerstrokes like it hot... |
First, don't go off the factory gauge. Use something real if you wanna know actual temps.
BUT you probably have a bad thermostat. I like my 203*F one. I get up to 180*F - 185*F unloaded, and maybe up to 195*F unloaded in the summer in TX. Maybe my old one was bad, but with the 203*F, it idled quieter, a tad, once at full operating temp. Does it help with mileage? Eh, maybe, but probably not enough to notice. But I like it. |
thanks guys stat and housing are on the way
You need to flush a certain way.
You should use a T in a heater line, back flush a while. Then drain out by either just dumping the water in the rad. or that and plugs in the block. I did just the rad. Then refill with tap water, run, and dump. Do that until the water coming out seems clear. Then fill with distilled water, run dump. Do that a few times to get as much tap water and minerals out. Then you refill with 4 gallons of CONCENTRATE antifreeze made for diesels. You shouldn't use a CAT EC-1 rated coolant due to motor year, but a proper SCA diesel coolant. Then refill up to the mark with distilled water, run the motor and just keep topping off. Total capacity is 8 gallons. |
I am curious about how the 203 degree thermostat affected oil temps.
PSD,
I think that this will answer all of the questions raised in this thread: Gooch's Radiator/Engine Backflush Procedure and Coolant Information - Ford Truck Enthusiasts Forums Dick |
