70 Dana 60 in a 95? - Ford Powerstroke Diesel Forum
Old 02-15-2013, 08:46 AM
70 Dana 60 in a 95?
Will a Dana 60 out of a 70 f250 work in s 95 forgot that dad had one floating around the farm out in a shed
Sent from my DROID RAZER HD while fixing my wrecked truck
Old 02-15-2013, 08:47 AM
Short answer is no, not bolt in like 86-97
Old 02-15-2013, 08:52 AM
Re: 70 Dana 60 in a 95?
Thanks had to ask as I just seen it sitting there
Sent from my DROID RAZER HD while trucking
Old 02-15-2013, 08:54 AM
It can be fabbed, but it is not the one your looking for to do a sas
Old 02-15-2013, 09:12 AM
How hard would it be to fab? My ttb is froze in 4x4 and I'm tired of that crappy front end
Old 02-15-2013, 09:14 AM
Is the 70 axle coil or leaf? Y don't you pull your ttb hubs and remove the guts?
Old 02-15-2013, 09:25 AM
Iirc the front axle from the 70's is a heavy duty Dana 44 not a Dana 60 the pumpkin is more in the center and will hit the front cross member
Old 02-15-2013, 10:34 AM
Not to mention its a standard rotation, closed knuckle, drum brake set up.
Sent from Nater's Android phone.
Old 02-15-2013, 10:44 AM
Well then I'm on the hunt for a Dana 60 out of a 86 or newer then
Old 02-15-2013, 11:17 AM
Keep in mind the 86-93 have slide pin calipers, the tip that sticks out on your brake line block that bolts to the caliper will need to be grinded off, and 94-97 is a direct replacement and uses same calipers
