I was messing around under the hood looking for more boost and how to get it I know about the MAP sensor and what it does, I also know about the mod you can do on the outgoing wires to modify fueling and I tried that and I dont like the idle on the engine. I have tried pulling the boost tube off and it wont fuel the engine properly and has no acceleration because it isnt reading so I pulled the plug out of the map and the truck idles great gets a little better mileage and roars power all I have Is a diy intake the truck will roll the smoke good in 1 and 2nd gear and almost anytime I lay on it itll roll it thin Im also getting 15psi easy and if I push it out I can get 20 and hold 18psi in every gear I know its not alot but I think im getting 35-45 hp it slips the tires easy in 1st without powerbraking I really love the power and the smoke but the check engine light is on and I know why I was wondering about harming the engine long term I only drive to school and pull a 30' gooseneck around and Ive only had it off 2 days good or bad mod?
any opinions +/-
any opinions +/-
