f350 front spring thickness
Ok, so im doing a D60 swap. Trying to buy used spring from the local auto recycler. What is the thickness of the stock front springs? ( i know i should get sd springs and rsk but not in the budget right now) The guy at the counter said theres a 1.45" and 2.03". I talked to a few guys in another thread and one measured his from a 95 and it was about 2". But another gave me his spring code from his vin and when i looked it up it was a 1.45" and that truck was a 86. Any help would be nice, or opinions. Thanks!
And its the thickness of the whole pack
here's a pic i get ~ 1 3/4.
![]() i would think that you want a set of 350 springs that are 2 leaf i wouldn't think there were many options except weight |
Well im told they both have 2 leafs. and when i looked up aftermarket they have 2", 1 7/16, 1 13/16, and 1 17/16 (idk if a typo on the website?) but the 1 13/16 have the lowest capacity with 2,200 lbs.
But since i want used do i get the thinnest hoping for the best ride? cause the 1.45 would be just over 1 7/16 |
Ok, i got the quote and one is a 89 F250 2wd 5.8 with the 1.45 and the other is a 91 F350 4wd with a 7.5. will either of those do any good?
The f250 should be coil sprung if its 2wd so get the f350 springs
STOCK FORD springs are 1.5". but Both the small block and BigBlock/diesel springs measure the same
AFTERMARKET 3 leaf springs are probably the 2.03" |
So the big block springs would work fine?
Yes, they are also know as diesel springs. I told you that in your other thread
