Front Shock Lower Mount
Was wondering if the front lower shock mounts on a 97 350 were replaceable seperate from the leaf spring or are the mounts part of the leaf spring. Want to replace one of mine and dont want to remove the u bolts and find the mount is part of the spring.
The mount is part of a plate the u bolts hold that to stay secure above the leafs
It is seperate. U can replace them by droping the u-bolts. I think terryknight may have some if u need some. Not sure if the d-60 ones are the same as the d-50 ones he has
351 yes thats exactly the part im talking about the plate with the bent up eyelets which the shock bolts to.
And ok great. One more quick thing what is the little thread part that comes up through the middle of the plate? |
That's the bolt that holds the spring leafs together.
And centers it where it needs to be on the axle as well
