Chip or Prog for OBS - Ford Powerstroke Diesel Forum
post #1 of 16 Old 12-14-2007, 07:33 AM Thread Starter
I have a '96 with Intercooler, Banks trans Command, and Banks chip (whatever its called) I'm looking to upgrade to a better chip/or prog, what is best for these OBS, would a chip(like 6 pos switch) from TS or TW work best or is a programer better then what I have now? Edge or something ok??
Pest007 is offline
post #2 of 16 Old 12-14-2007, 07:36 AM
Raul@Stealth Automotive's Avatar
def go with a Tony WIldman chip.... it will be your best setup
Raul@Stealth Automotive is offline
post #3 of 16 Old 12-14-2007, 07:38 AM
cowboymafia's Avatar
Send a message via AIM to cowboymafia
twildman or dp tuner with tunes from elite
1996 dodge 3500
the new toy
cowboymafia is offline
post #4 of 16 Old 12-14-2007, 07:39 AM Thread Starter
Thats what I have been hearing, I was leaning towards that, but not sure how to go about install and what you have to do. I'm not even sure where to check to see if I have a banks chip
Pest007 is offline
post #5 of 16 Old 12-14-2007, 07:40 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Tony Wildman www.totaldieselperformance.com
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #6 of 16 Old 12-14-2007, 07:41 AM
Got Diesel?'s Avatar
I had a bully dog 6 position chip for a month and it was ok. then i bought a dp tuner 6 position chip and im loving it
The new Truck
2005
F350 4x4 CC, DRW, LB, Auto
106000 miles, King Ranch Edition,
5 inch duals, sct tuner
My old Truck that I still have
1997
F-250 4x4 EC, SRW, LB, 5 Speed,
246000 miles, k&n cold air intake, 3 inchdown pipe,
5 inch daul silverline stacks, DP Tuner F5 6 position chip, Shimed FPR
October 2008 Rig Of The Month WINNER
[/CENTER]
Got Diesel? is offline
post #7 of 16 Old 12-14-2007, 07:41 AM
You have to pull the CPU out. You may be able to see the back side of the CPU behind the parking brake, but it will be difficult.
Derrick
post #8 of 16 Old 12-14-2007, 07:41 AM
it gets installed in your CPU... its actually quite easy... here is a short video of how a DP chip is installed but its the same exact steps to installing a TW chip Diesel Movies - I install a DPTuner F5 chip in my buddies truck. Positions were Stock hi idle 60tow 80econo 120 race 140smoke.
post #9 of 16 Old 12-14-2007, 08:02 AM Thread Starter
cool, I remember seeing that, but wasn't sure if everything was basically in the same place on an OBS truck
Pest007 is offline
post #10 of 16 Old 12-14-2007, 08:12 AM
I would use a 6-pos from Elite!
forddieseltweek is offline
