Did I do any damage to my rear differential axle tube??? - Ford Powerstroke Diesel Forum
Old 02-12-2013, 03:02 PM
Had to replace my LR axle seal today and the situation i was in when putting the truck back down off the blocks was to lift up and let down the axle by using a floor jack and 2x4 under the axle tube right under where the axle vent tube connects. It was supported there for only 5 minutes or so. Is my axle tube ok???
Old 02-12-2013, 03:03 PM
It's fine, I lift on the tube and and shock mounts all the time
Old 02-12-2013, 03:04 PM
Yeah, you are fine. Where did you think you should lift from?
Old 02-12-2013, 03:33 PM
Hillbilly Deluxe
Feedback Score: 3 reviews
Dude you run your 8000k truck down the road on that axle tube... i am fairly certain that lifting it with a floor jack wont hurt it...
Old 02-12-2013, 03:36 PM
Agreed that BS about not lifting from the tube is crap
Old 02-12-2013, 04:05 PM
Trailer axle tubes are different. But you've got a big diff in the middle.
Old 02-12-2013, 07:26 PM
Thanks guys. I always lift from the pumpkin. Makes sense when thinking about it if the tube was that weak you would have major problems on the road. It was a cluster F under there when i was done and the tube was the only solid place i could lift at.
