International waterpump - Ford Powerstroke Diesel Forum
Old 02-09-2013, 03:47 PM
For those of you who have installed the
International water pump
part #1831676C92
were there any other parts that had to be changed over on the OBS?
Also what will the filter # be?
Thanks
Sent from AutoGuide.com App
Old 02-09-2013, 05:12 PM
Try these links:
Int'l water pump w/ filter...installed - PowerStrokeNation : Ford Powerstroke Diesel Forum
IH water pump with filter. - PowerStrokeArmy
Some of the info is duplicated, but it should still be good info. Hopefully your 95 doesn't have the same configuration as the 94's since I can think of only one person that figured out a good way to do the bottom radiator hose (they are on different sides on the earlier trucks). I also can't seem to find the info on that one person's solution. As far as the filter goes, you can get coolant filter with various levels of SCA (including zero SCA, just a filter which I would choose to go with and then just monitor levels as one would normally do). Cheers!
