Air filter change indicator
When you change your air filter does the condition indicator have a reset or what.
thanks,tony |
Yea mine does the little clear plastic indicator with the yellow rubber reset cap you just push it in and it resets it. If thats what you are asking.
Oh and Welcome to Org man!!!!
must be broke
changed filter ,pushed reset ,still says change.
thanks, tony |
Does it reset and then show plugged again after you run the truck...or does it just not reset??
them things are kinda a joke anyways
they actually work better than you realize.....especially on the donaldson filters in the AIS kits for the 7.3's and the stock 6.0 filter...
well i have a afe stg 2 u can pretty much tell when it needs cleaned
Marc,
Does it reset and then show plugged again after you run the truck...or does it just not reset?? >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>> It just don't move ,still shows needs changing. thanks __________________ |
It's probably froze up and just need a new one should be fairly cheap.
