Replaced cps still have issues - Ford Powerstroke Diesel Forum
Old 02-09-2013, 05:46 AM
About a month ago my truck died and I figured it was the cps.. just replaced the cps and its still having a tough time. I got it to run for about 5 minutes then it sputtered and died. Plenty of fuel and tach bumps when cranked.. whats the deal?
sent from a smoke signal...that I took a picture of with my S3..then translated to english words.
Old 02-09-2013, 06:27 AM
Re: Replaced cps still have issues
Id like to get this turd running today...
Old 02-09-2013, 11:13 AM
How's the oil pressure when cranking hpop res level do you have access to a scan tool. I had a low pressure oil pump fail can't fill hpop res then same truck also wouldn't run when new motor was installed I had weird injector codes turned out to be idm would also want to check icp sensor with scan tool and ipr sensor
