let's talk brakes - Ford Powerstroke Diesel Forum
post #1 of 53 Old 02-08-2013, 01:42 PM Thread Starter
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
let's talk brakes
i am hoping someone here can help me out. i apologize in advance this will be fairly long. this problem has me scratching my head.
i bough a 97 drove it almost 1000 miles brakes worked great, went to get it MD inspected, needed to replace the front brake hoses and secure the left brake line. okay no problem. i wind up breaking all the front brake lines at the flare fittings due to rust issues (CT truck). No problem bend and fair new lines, install new lines, install new hoses, bleed brakes, take it for a test drive everything works great no lights, no problems, passes inspection. I park it for about two weeks get tags, yada yada. i hop it it to go somewhere start up the truck brake light on the dash is illuminated, i think building vacuum, vacuum builds (i have a gauge pulls about 26), light stays on. i try to release the e brake (never set it, but maybe something is sticking) light sill on. so i drive it down the road and back brakes feel great good, hard pedal, no fading. I take my trip in it, light still on. okay next week take it on a long trip, light still on, brakes still great. come home i'll fine the cause. bleed the brakes can't open rear bleeders (CT truck), replace rear wheel cylinders. bleed brakes great pedal light still on and now ABS light is on too. maybe a vacuum leak, i tighten up all vacuum lines, all position on HVAC work great, light still on. start it up today ABS light is off driving around the ABS light comes on and then off and then ON again seemingly random.
SO.... where do i go from here? bad wire somewhere grounding itself. bad sensor? bad booster? bad master cylinder? what sensors can illuminate the brake light? the ABS light? what are the reasons the brake light can be illuminated? i can think of low brake fluid - it's full, e brake on it's not, broken line resulting in loss of pressure - no leaks i've found, loss of vacuum - vacuum is great. what are the reasons that the ABS light can illuminate? i can only think of something wrong with the sensor/module.
any thoughts opinions?
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #2 of 53 Old 02-08-2013, 01:58 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Terry, PM me an email address.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 53 Old 02-08-2013, 02:10 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Matt
'97
-Stage II trans.
BigFuel is offline
post #4 of 53 Old 02-08-2013, 02:13 PM Thread Starter
the baconator
Quoted: 143 Post(s)
got your email going to do some reading
EDIT: thanks
post #5 of 53 Old 02-08-2013, 02:29 PM
kraker829's Avatar
Re: let's talk brakes
Had a 97 F450 in shop do exactly the same thing to us. It was the switch under the reservoir.
Sent from my SPH-D710 using AutoGuide.Com Free App
kraker829 is offline
post #6 of 53 Old 02-08-2013, 02:58 PM Thread Starter
the baconator
Quoted: 143 Post(s)
well matt that looks like a long time consuming task, good thing i have lots of time this weekend. where did it come from. Thanks
kraker - that is one of the things on matt's list
post #7 of 53 Old 02-08-2013, 03:04 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Like most everything OBS digital:
http://www.thedieselstop.com/faq/949...e=stjsd10r.htm
Save that link if you don't have it
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 53 Old 02-08-2013, 03:15 PM
kraker829's Avatar
We have accesses to the Ford site but it's pretty fickle most days. I have to save and copy and other bs to post schematics here.
post #9 of 53 Old 02-08-2013, 04:00 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
How about vss (also the abs sensor)? It would also cause these lights to be on.
Sent from my SPH-L710 using AutoGuide App
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #10 of 53 Old 02-08-2013, 05:19 PM
kraker829's Avatar
Big fuel that site is awesome! Way better than the Ford site at work! Thank you
