Ebpv question
Everything is in the world for a reason. But do you really need the ebpv or is there a delete or gutted i can do.
I posted yesterday about my turbo trying to keep producing back pressure, and 2 different ppl said it is the ebpv. i want to get away with not putting a lot of money in it for a new one. everyone knows money is tight. What can i do about the ebpv?? |
Yes it can be gutted, or you can just unplug it for now. There is a plug on the drivers side of the turbo, the wire comes under the intake tube and the plug is attached to the side of the turbo, unplug it and it won't turn on anymore. This will set a code but it will not turn on check engine light unless you have california emissions then it will
I unplugged mine just as djs said. Worked good. No light just as he said, and I dont have to deal with it opening and closing all the time. Thanks
Or you can convert it to a DIY exhaust break.
is this the plug?
Does the connector have two wires? I've looked, and can only find 1 connector in the location that has been described, i just want to be sure. the connector is just under and foward of the turbo.
