'96 7.3 HPOP RESEVIOUR LOW OIL LEVEL?? - Ford Powerstroke Diesel Forum
Old 02-06-2013, 05:04 AM
If the HPOP oil level is low and its not leaking, where is the oil going? And what should the normal level be. I'm assumeing it should be full, but don'nt know for sure. And am I correct in saying that the LOW PRESSURE OIL PUMP is the main oil pump for the engine?as well as for the HPOP?
Old 02-06-2013, 06:43 AM
Yes the low oil pressure pump feeds the engine as well as the high pressure oil pump not sure exactly what the level should be. I do know it only run abou 20 sec off what's in the reservoir if not being supplied
Old 02-06-2013, 07:49 AM
Back into the oil pan.
Within an inch or so of full.
Correct; some call it the "low pressure oil pump", as if it's some specialty part, but it's really just the same kind of oil pump as found on any engine. It also supplies the oil to the HPOP, through the reservoir.
Old 02-06-2013, 10:58 AM
Thanks Guys this answers some questions. Next ? should the reseviour stay full between start ups or does it drain back to the oil pan?
Old 02-06-2013, 01:11 PM
It should stay full.
Old 02-06-2013, 03:42 PM
yep it did , its good Thanks
