1.0 turbo housing? - Ford Powerstroke Diesel Forum
Old 12-06-2007, 04:33 PM
1.0 turbo housing?
I thought I read something about a 1.0 turbo housing. Does this use the stock wheel and internal parts? What exactly is the difference between stock and this housing, and what are the benefits?
Old 12-07-2007, 06:47 AM
7.3 tech, supporter
Factory turbo housings are around 1.15:1 air ratio, they make a 1.0 and .85 housings also. They are just smaller housings that allow the turbo to spool up faster at lower RPM's however you will loose a lil top end power. If you tow alot this might be a good option as long as your not gonna race the thing.
Basicly your just replacing the exhaust housing with a smaller one.
Old 12-07-2007, 04:46 PM
BIG TRUCK, SMALL DRIVER
I had a 1.0 housing on mine before I did my injectors. It made a good improvement when towing and made the turbo spool a couple hundred RPM earlier. If it were not for the injector upgrade, I would still be running it. If you decide to swap it, check out this link. It will help a lot. OBS turbo removal/installation tips
Old 12-07-2007, 09:23 PM
The 1.0 housing is a little smaller than the original factory 1.15 housing. This means the same amount of exhaust gas will move at a higher speed through the smaller housing and moving more intake air into the engine at a lower rpm. This increases torque at a lower rpm and the turbo spins up faster. Good for RV use because of the low-midrange power increase. The power dropoff at the top end is minimal. I got 408 hp/14.5 quarter times using a 1.0 housing and stage II injectors and had over 80K miles on the turbo/;housing.
