What are these mods and what do they do - Ford Powerstroke Diesel Forum
Old 12-06-2007, 11:39 AM
Can you guys tell me what these mods are and what they do:
Shimmed FPR
10K mod
EOT mod
FOIL Delete
FPR MOD
FPR Shim
Power elbow
zoodad mod
Old 12-06-2007, 11:52 AM
7.3 tech, supporter
Ok, the shimmed FPR, FPR mod and FPR shim are all the same, it consists of removing the Fuel Pressure Regulator (FPR) and placing a BB under the spring to increase fuel pressure (about 20psi). This will add a lil more HP and smooth the idle.
The 10k and EOT mods consist of inserting a resistor inline with a couple sensors to fool the computer and allow higher high oil pressure, Personally I didn't notice a big difference and the 10k made my truck idle pretty rough.
Old 12-06-2007, 11:54 AM
do you think its worth to shim fpr? and if it is, how do you do it
Old 12-06-2007, 12:00 PM
7.3 tech, supporter
I think it is worth it since it's practically free and does help. Derik did a pretty good write up on it here....
OBS FPR Shim and Gauge Install
Old 12-06-2007, 12:01 PM
Send a message via AIM to submariner Send a message via Yahoo to submariner
what mods that are DIY that make i differnece and don't kill milage?
BIG TRUCK, SMALL DRIVER
Shimmed FPR, Shimming the Fuel Pressure Regulator for More pressure going to the Injectors, OBS FPR Shim and Gauge Install
10K mod, A resistor mod that "fools" the computer to raise the injecton control pressure, 10k resistor mod.
EOT mod, Engine Oil Temp mod, I think?
FOIL Delete, Removing the sound deadening material from the intercooler tubes for louder turbo, '99.5 and later 7.3 SD's
FPR MOD, Shimming FPR
FPR Shim, Shimming FPR
Power elbow, Improved Air intake on 6.0's
zoodad mod, like a ram air system, ZooDad Mod
Old 12-06-2007, 01:22 PM
thanks for the help guys
Old 12-06-2007, 03:34 PM
the fpr shim did a help alot for me. it made my truck idle a whole lot better and it does seem to have a lil more power. it blows a lil less smoke too...which to me is a sign of improvment
