charging batteries - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-03-2013, 03:15 PM Thread Starter
charging batteries
i was just reading another thread & the advice was to charge batteries seperately. a friend who is a ford mechanic had told me it does not matter. why would the batteries need to charged seperately? i've recently charged them at he same time. what damage might i have done?
rober is offline
post #2 of 9 Old 02-03-2013, 05:05 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Re: charging batteries
None what so ever... I charge mine together all the time. 12 volts is 12volts
Sent from my SPH-L710 using AutoGuide App
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #3 of 9 Old 02-04-2013, 08:40 AM
If you have a bad cable or something like that and your batteries aren't provide equal amounts of power to the starter motor, then you'll have one that is lower than the other. Charging them together with an automatic charger probably won't allow the lower battery to fully charge.
sgg93 is offline
post #4 of 9 Old 02-04-2013, 08:58 AM
Hillbilly Deluxe
Quoted: 2 Post(s)
I disagree completely... Volts are volts and amps are amps. The condition of the cable dosent have anything to do with charging or discharging the batteries. Loose connections may cause and issue but it dosent matter if its #4 or 18ga its still 12v.
If your really concerned about the cable between the batts it runs right on top of the core support...
Seth
Stroked_NY_023
post #5 of 9 Old 02-04-2013, 09:14 AM
Quoted: 5 Post(s)
Some automatic chargers won't charge both batteries effectively if one is "flatter" than the other.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #6 of 9 Old 02-05-2013, 08:33 PM
They're in parallel, so if you charge one, the other is being charged also.
Dick
tartansailor is offline
post #7 of 9 Old 02-05-2013, 09:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I charge them together, but a "bad" battery will inevetably Sak the other, so that is why seperatly is said, but if they both test fine charge together
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 9 Old 02-06-2013, 08:19 AM Thread Starter
i should have been more clear. my question should have read is it ok to charge both batteries at he same time. i put a trickle charger on each battery. it still sounds like it is ok to do so.
rober is offline
post #9 of 9 Old 02-06-2013, 08:56 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yes that's fine
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
