Help!!! 96 7.3 no start, daliy driver - Ford Powerstroke Diesel Forum
post #1 of 19 Old 02-03-2013, 11:07 AM Thread Starter
Hey guys , o.k. yesterday very cold out in the am . and I did 'nt plug the block heater the night before because I did'nt think i'd need to go anywhere in the am. Woke and surprise my daughter needed a ride. So out to start the truck I went. I knew it would be a difficult start as the glow plugs a shot . Cycled through the glow plugs a few times, Cranked motor over and i got the usual smoke from un burnt fuel coming out from under the hood and tail pipe, continued to cycle glow plugs a few more times and did get it to fireup a short burst (as it usually does when this cold and no block heat the night before) I continued to cycle glows , and crank over till i run the batteries down and had to charge them. tried all day and could not get it to fire over. so I drained the fuel filter housing till empty , closed drain valve and tried to restart with no luck and fuel filter housing would not fill with fuel , checked all fuses pertaining to injectors, fuel, checked glow plug relay etc. all good so I changed out the fuel pump today and the fuel filter housing is very slow to fill up. I cranked it on and off for about 3-5 min and the fuel is just above where the bottom of where the base of the filter rests. is this normal to take this long to fill, any Ideas where to go next? oil is full also This is my daily driver and i need it. Cant afford to loose work. Oh yeh. Just to let you know tech doesn't move , but every so slightly when i crank it over if this means anything thought I read it somewhere in this forum with this issue.?
Abzack is offline
post #2 of 19 Old 02-03-2013, 11:24 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Weak batteries still and if new pump and very slow to fill mite wanna try some power service or something to ungel that fuel, and go ahead and plug it in now too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 19 Old 02-03-2013, 12:57 PM Thread Starter
yeh I believe the batteries are weak at 4yrs. old now! now on the charger and does fill filter housing a bit faster with a better charge now ,tech does move up to a few hundred rpm. I will put a complete charge on them and try it agin latter. when charging the dual battery set up do I need to charge both batteries separately or will they both charge simultaneously when chargeing the main battery?
Abzack is offline
post #4 of 19 Old 02-03-2013, 01:28 PM
creekfreak's Avatar
Charge separately.
Chad
95 ECLB 4x4
Rebuilt e4od
320k kilometers (Canadian truck)
BHAF DIY mod
Cat/muffler delete
Diamond Eye 3" downpipe
Western pro-plus plow on an ultra mount
Running Goodyear Dura-tracks on stock rims.
If you're wondering about the handle... Creekfreak... I paddle hard, steep, whitewater. It's been my online handle for about 15 years.
creekfreak is offline
post #5 of 19 Old 02-03-2013, 01:33 PM Thread Starter
do i need to disconnect the positive cable on the secondery battery when charging it?
Abzack is offline
post #6 of 19 Old 02-04-2013, 05:12 AM Thread Starter
Changed out batteries, new fuel pump is pumping fuel good and fuel filter housing is full of fuel , but engine still won't fire .Now what could it be the fuel regulator on the side of the filter housing? This is my first diesel so please bare with me . Iam very mechanical and always do my own work, but don't know the disels that well still leaning . HELP!!!
Abzack is offline
post #7 of 19 Old 02-04-2013, 05:42 AM Thread Starter
does'nt seem like fuels getting to the injectors, no white smoke ?
Abzack is offline
post #8 of 19 Old 02-04-2013, 07:53 AM
erics diesel's Avatar
Have you checked the oil level in your hpo reservoir? Could be an oil issue since these are heui injectors
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #9 of 19 Old 02-04-2013, 09:34 AM Thread Starter
no eric did'nt check the oil level in the hpo reseviour . How do I do this ?
Abzack is offline
post #10 of 19 Old 02-04-2013, 09:40 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That thing on the front of the motor has a nut on the right side, remove it and use a "dipstick" to check level, it's a metal reservoir kinda thing sorry I don't have piks to explain
Idm could also cause this issue
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
