heat issues.
when the truck gets warm i turn on my heat and it is hot for about 15 secs then goes cold. Is this a thermostat gone bad or something different?
Sounds like heater core
is there any way to check to make sure that is what it is?
i am going to change out my heater core today. I am going to drain out the coolant out of the radiator what coolant should i get to replace it with?
Try back flushing the heater core prior to replacing. Remove hoses and connect garden hose to return side, then reverse to check the flow.
I used 2 gallons of extended life coolant and 4-5 gallons of purified water
so i replaced my heater core today, i am glad i didnt take it to a shop and let them charge me for 8 hours worth of work it was simple. But was not the issue... i had to buy too heater cores because they offer a light duty one and a heavy duty one and i wasnt sure which one it took. any way after getting it all back together and driving back to the parts store when the truck got heated up i turned on the heat and it still blew cold air out... now i am upset ha so i returned the light duty heater core and told the guy that it didnt fix my problem. He recommended a radiator cap and sure enough for 6.99 before i left the drive way it was blowing out hot air.
That's actually funny as hell, mine doesn't have a radiator cap
why not? Isnt that kinda important
It's totally important. It affects the boiling point.
