Head Gasket Questions...
With my build slowly coming along...
What should I do about my head gaskets? I've been reading that stock fresh head gaskets and studs will not safely hold 40-50psi until they have been "aged". What other options do I have? Fire Ring Head Gaskets are super pricey... Would much rather spend the money elsewhere... Trucks mods: 250/100 injectors BDP modded H2E 910 Springs DI PushRods Mahle pistons (machined bowls) Forged OEM pistons?? E-Fuel (Obviously )T-500 HPOP Looking for 500hp - 575hp Thanks again guys! |
Dont pull the heads. Just take one bolt out at a time and replace it with a stud
With that set up, your looking at fire rings, o-rings may hold, but when doing a build like that, may as well do it right. Also your t500 may not hold pressure well with the 250/200s. May wana step it up a notch.
![]() I've read some horror stories about the fire rings. They are only 250/100's. Beans said that the t500 would keep up. ![]() What HPOP set-up would you recommend? |
Id go with a srp1.1 but its a love hate thing. If beans said they would keep up, they would know better then me. Just seems like thats a small pump to run a good duty cycle and not run the pump for everything its got.
Now for the next question... Forged Cyro Peen-shot rods... or billet rods? $600 vs $2650 |
Just keep in mind there are quite a few horror stories about the srp1.1 but there are plenty of guys that have no issues that dont post up their good experiences. Just want u to be aware of them b4 u commit to a purchase.
As for rods, i hove no experience. I know plenty of guys who are running 250/200s on stock forged rods, but they also have a spare motor just in case it pukes a rod. |
A stock 17* or any symilar pump, can run a Hybrid but for better results you need a pump like the srp1.1 that provides more volume...
Called RiffRaff and left them a message regarding the return of my T500.
Will order the srp1.1 soon. ![]() I don't want to make another thread, so could someone please chime in on the following question: I ordered two 16" 1/4" braided lines, is this a sufficient size for the supply lines to the back of the heads from my y-splitter. The stock fuel line size from the lift pump to the heads was 1/4" so i figured it would suffice. Now that I am aiming for 500-575hp I am questioning my decision... ![]() Thanks, Andrew Last edited by Pwnm30rdi3; 02-04-2013 at 09:20 AM. |
