cold?
my stroke sits for bout 30 min before i leave for work the temp dosent leave the cold mark and get into the normal area untill i about 15 miles down the road. i stop and it goes back down to the cold mark. by cold mark it is bottomed out cold or close. any imput on the dump valve and how i could test it to make shure it works. or what else i could look into to get the blue goose up to runnin speed.
Make model year mods etc?
Where you at and how cold is it? What you talking about when you say dump valve? Sounds like you got a bad thermostat. Mine gets warm and stay there in about 2-3 miles from a cold start. It will also warm up idling for a few minutes. My exhaust back pressure valve is tied open and I found that it made no measurable difference in warm up time. I referring to outside temps around the freezing mark. It seldom gets below 20F here. |
sorry 05/94 stock im in LA it not but 40 or 50. the exhost back pressure valve. the thermostat is the same as a older gas. under the hose to the radiator?
Sounds like the T-stat is stuck open. Be prepared when you do this to replace the T-stat housing also, they are stamped steel and prone to leak when you replace the t-stat.
