Headlights = kill switch - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-31-2013, 05:46 AM Thread Starter
vandy's Avatar
A while ago, one of the first cold mornings. Truck has idled for maybe 10 minutes. I hop in put it in rev. Hit the headlights and the truck shut off. I didn't think much about it.
This morning driving to work. Rigs been running for about 30 min. I pull thru the gate. Dim my lights. Pull thru lights back on, truck shuts off. I coast to a side road. Cycle the key and she fires right up.
I know your lights are on a constant hot, your ignition has a constant hot. But other than that I'm not sure why one would cause the other to shut off. Any thoughts?
vandy is offline
post #2 of 21 Old 01-31-2013, 08:14 AM
Quoted: 53 Post(s)
Did you happen to notice, when it happened while you were moving, did the speedometer drop to zero?
madpogue is offline
post #3 of 21 Old 01-31-2013, 08:16 AM Thread Starter
vandy's Avatar
Re: Headlights = kill switch
Not a 100% but i think the dash lights/power went dark
vandy is offline
post #4 of 21 Old 02-01-2013, 02:13 PM
Gertrude's Avatar
Send a message via Skype™ to Gertrude
I had the same thing happen to me when I started my truck on a cold night when I was leavin work, the battery gauge was really low and I turned my h/l's on and the hids suck a lot of power, I guess from that and the gpr being on it killed the truck which I thought was weird, because I just put two new motorcraft 850cca batts in it but it fired back up with no problem. Another time, again it was cold and I was leavin work, I started the truck and flipped my lights on after about 5 seconds and the truck shattered like it almost died, the cel came on, and the "off" on the shifter was flashing, I put my foot to the gas pedal and nothing, the truck didn't rev up so I restarted it and everything was fine, it never done either of the two symptoms again and I guess it was just the cold weather and me being hard on the batteries
Andy=23
Future Mods: Project Revive/Rebuild/Restore
Too many cars, not enough money.
Gertrude is offline
post #5 of 21 Old 02-01-2013, 11:15 PM
I have the same sort of issue, except that it doesn't die outright, but when cold the idle will bump up and down as if the GPR was cycling off - which it isn't - and continue to do so for a few minutes until the GPR has finally switched OFF.
Lights go bright and dim with the idle speed, and trying to give it any pedal seems to make the problem more severe.
Hope someone has an idea what might be causing these problems.
I replaced the GPR back in November, so I don't think it is the issue.
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #6 of 21 Old 02-02-2013, 12:58 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Do you have a dp tuner?
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #7 of 21 Old 02-02-2013, 05:54 AM
Can't speak for the rest, but I'm quite sure that I don't...
Qwazert is offline
post #8 of 21 Old 02-02-2013, 05:57 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Sounds like something is grounding out from inside the headlight switch and killing the power to the ecm....could find another headlight switch and swap it and see if it happens again.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #9 of 21 Old 02-02-2013, 06:00 AM Thread Starter
vandy's Avatar
No do tuner. Truck is stock to the best of my knowledge. It's got an aftermarket radio and tow brake controller.
Ive got a new set of batteries and new GPR. The first time i figured it might be just an overload on the system being that it had pretty much just been started and a cold day. But the last time i had been driving for 30 min. If it keeps happening I'm gonna tear the dash apart. So far it's happened in places that were pretty safe areas. I'd hate to be towing a load down a busy highway hit my lights and loose all power and kill the motor
vandy is offline
post #10 of 21 Old 02-02-2013, 07:11 AM
Quoted: 53 Post(s)
Does it happen when you pull the switch to the parking light position?
madpogue is offline
