Add-a-leaf install question
I got a superlift add a leaf today for my f250 anybody have any advice on the install and pics to help me see how its done? Thanks
Sent from my DROID RAZER HD while fixing my wrecked truck |
Is it just short leafs or does it have a ttb drop bracket? All it should be is remove u bolts from axle surrounds, pull leaf off axle put the aal between them and use supplied u bolts to put it back together, should be pretty simple, be prepared to have an alignment done as soon as you finish
Rears? Lets see if I can remember from when I did mine.
Jack rear of truck up under the hitch. Put another jack under the rear axle and remove the wheels. You may need to unbolt the shocks so you can drop the axle enough. Pry the metal clamps apart that hold the spring packs together. Remove the U-bolts that connect the spring pack to the axle. Remove the one bolt that hold all the springs together. Drop the axle enough to separate the springs so you can get the new one in there. Assembly is reverse of removal. Sorry I don't have any pics. |
Re: Add-a-leaf install question
Sorry its for the front and no brackets they were supposed to send the center pins but again nothing
Sorry its for front and no no brackets it was supposed to come with center pinsbut then again they didn't send anything
Mite wanna make some calls and chew some heide, or go buy the bolts at pep boys or something, stock u bolts are gonna be to short
Yeah I got off the phone with Summit Racing and they're going to send me out the new center pins and I'm going to the local NAPA store to get u bolts how long should I get them couple inches longer than stock or what?
Just an add-a-leaf you could get away with the stock ubolt. However if they have never been removed before I would definatly have a set on hand!!
Sent from my SPH-L710 using AutoGuide App |
Big thing about the length is those bolts is getting that nut back on lol, and the cheap bolts will twist, we twisted the crap out of a couple doing a 6" lift
Yeah or they snap off or the nut wont budge.
I get my ubolts from Jeffs Bronco Graveyard. Very good pricing on oem equipment. Sent from my SPH-L710 using AutoGuide App |
