My experience removing exhaust manifolds.. - Ford Powerstroke Diesel Forum
Old 01-29-2013, 03:57 PM
I get a lot of information on this site and folks are always ready to lend advice. Hopefully this will help someone that hasn't ever taken their manifolds off. If you have trouble getting one of the bolts loose, most likely it's not because the threads are stuck in the head. The mounting holes in the manifold are big enough to allow moisture and all sorts of crap to accumulate around the bolt and basically weld itself to the manifold. When they get stuck, they are stuck good. I spent an hour and a half on one bolt tonight. I had to finally use the torch to blow out the remainder of the bolt from the manifold. The fatory bolts are very hard and a drill is almost useless. Another thing I learned the past week or so is, it sure is a lot easier to work on these engines when they are on a stand!!!
Old 01-29-2013, 04:13 PM
I usually use a 3/8 impact and tighten just a bit before loosening them and gets em right out most of the time.
Old 01-29-2013, 04:20 PM
And thats why i'll be pulling the cab when i get around to doing my manifolds. I've got all new SS hardware and high-temp anti-sieze for when i put it back together.
Yep. For whatever reason I find tightening a fastener and then reversing in a quick succession breaks it loose. Note this trick doesn't work for turbos. I had to use a torch to get the compressor and impeller housings off (heat not cutting).
Old 01-29-2013, 04:43 PM
heat is a big key. i was removing broken manifold bolts last week patience and heat are key heat let cool heat let cool try it if it don't turn right away more heat. got 4 from the head and 1 from the turbo flange of a 12.5L john deere that way didn't drill any even one that had less than a 1/8th in. sticking out from head
Old 01-29-2013, 05:05 PM
How the heck did yall grab onto them vice grips?
Old 01-29-2013, 06:11 PM
i use stud removers and then a vise grip if the stud remover won't grip onto em
Old 01-29-2013, 06:36 PM
Is that like an easy out?
The last thing I busted was bolt in a geo metro waterpump. Was going as normal and then the head just busted off. Ended up having to tack another bolt to it and back it out.
Old 01-29-2013, 08:28 PM
Easy outs are amazing lol, and gator sockets lol
