Exhaust manifolds, gasket or no?
Looking for opinions on whether to buy exhaust manifold gaskets or intall without. I know my old gm diesel had you put a coat of grease on the flanges and torque em down.
No gaskets unless they are warped and then I would have them machined flat
To my knowledge, there aren't any gaskets even made for the 7.3. By design, it's a gasket-less setup, as per International.
Both IH and Ford have gaskets, as well as Fel-Pro's(aftermarket). From the factory its machined. I've heard many guys having great luck throwing on a set of gaskets when they have manifold leaks. I also believe multiple shops add gaskets when they have the manifolds off. I'll be adding gaskets when i pull my manifold off, and depending on how they look and what it costs, i'll be having them re-surfaced as well.
I know that Fel-Pro makes them for sure. Thanks for the input.
I know we put gaskets in my 97 when the motor went together this fall
Sent from AutoGuide.com Free App |
Part numbers for anyone that needs them:
Exhaust Manifold Gasket (Ford) F4TZ-9448-A (International) 1814219C1 Cheers! |
Fel-pro are inexpensive and I also will be putting them in along with a resurface
