97 rearend
i have the 97 in my signature and the rearend went and wrecked the housing. i know this rearend is a 4.10 LS. how do I know if it's a full floating axle. im searching for a used one and need tips on exactly what i need and what years will fit. help is greatly appreciated need to get this truck back on the road asap
If it's a 7.3 and a 3/4 ton then unless someone did some real rigging. it is a full floater. A quick way to tell is to look at the axle portion that extends through the wheel. If it has a cover held on by bolts then it's a full floater. Another tell is the fact it has 8 lugs on the wheel.
92-97 all have the sterling 10.25 on f250-f350 and used the vss to communicate to the speedometer, and 85?-91 all used same axel but speedo did not go off the rear, the 88-91 is capable once the tone ring and sensor are installed iirc but best bet is any 3/4 to 1 ton ford 92-97 single rear wheel will work for you with no issues
thanks for the help. just hopefully the one i found is in good shape
Re: 97 rearend
Another option is swapping in an SD rear. Get the hubs machined to 8x6.5 and you will have a stronger axle with disc brakes!!!!
Sent from my SPH-L710 using AutoGuide App |
fordF250 what part of the country are you in, i have a 410 limited in the houston area
I also have a 4.10 LS in NEPA
im in SW Pa but i found one and just got it put in. just glad the truck moves again.
what is the difference between a posi rearend and limited slip.
None to speak of, they are essentially the same thing.
