01E350 rear axel in a obs truck
Anybody know if this will work it has the obs bolt pattern and disc brakes any info would be great
Sent from my DROID RAZER HD while fixing my wrecked truck |
The frames are different so your going to have to modify the mounts, not sure if the width is the same or not.
Re: 01E350 rear axel in a obs truck
It can and has been done before. Axle will bolt right up, the van axles are the same width. You may have to mod the shock mounts though. Also I think there are issues with the parking brake.
I am planning a rear disc conversion but I will be swapping in an SD axle. They are wider and parking brake is not an issue. Bolt pattern is fixed by re-drilling hubs to 8x6.5 ... Sent from my SPH-L710 using AutoGuide App |
I'm interested in hearing more bout that SD swap and redrilling the hubs
Re:
Yes the e-series and SD rear axles are bolt in.
Heres another option... http://www.fordmann.com/F350.rear_disc_brakes.htm My plan is an sd rear axle with hubs re-drilled to 8x6.5 pattern. Local guy is charging me $10 a piece to machine and install studs. Only thing to consider is gearing. Sent from my SPH-L710 using AutoGuide App |
The E-series dana 60 and D70 are weaker axles that the factory Sterling 10.25
Agreed... That's why I will be swapping the 10.5 in my truck...
