Best chip for a stock power stroke - Ford Powerstroke Diesel Forum
Old 01-24-2013, 07:26 PM
What's the best chip for a stock 95 stroker it is currently going under a facelift thanks to a f450
Sent from my DROID RAZR HD while working on my wrecked truck
Old 01-24-2013, 09:36 PM
Send a message via AIM to Maverick1701
as long as you go with a custom tune you should be good....try to avoid canned tunes.
one of the main guys is tony wildman. Try a search there are several more out there who do custom tunes but I cannot think of them off the top of my head.
Old 01-24-2013, 11:44 PM
TS with Tony Wildman, Gearhead, Swamps, Beans, etc are all great.
PHP's new Hydra chip is a nice piece if you think you want more than 6 tunes.
Old 01-25-2013, 12:38 AM
Re: Best chip for a stock power stroke
I've heard a lot about them to Tony Wildman chips hey buddy of mine has 1 what would you guys suggest for the positions on the chip I pull a trailer quite a bit
Sent from my DROID RAZR HD using AutoGuide.Com Free App
Old 01-25-2013, 02:59 AM
Delivers Pizzas For Fun!
Stock, high idle, tow, daily driver, performance, race!
Or do a light tow, heavy tow, and take out performace
Old 01-25-2013, 07:49 AM
De-rail in 3... 2... 1...
Never had much use for "stock" setting myself when I normally live in Daily Driver. At least one of the guys in Backwoods' list will not burn a heavy tow without an intercooler installed. I would like to recommend that you consider in what order you get your tunes as much as what tunes you get. I prefer a U shaped setup where the lowest power setting is in the middle and you run left or right depending on what you are doing. Example, I run my tunes like this:
1: High Idle
2: Heavy Tow
3: Light Tow
4: Eco Drive
5: Daily Driver
6: Extreme
I tow a little less then I DD and in this layout I have a loaded truck side of the switch and an unloaded truck side of the switch.
Side note: Beans is emailing tunes again and selling a TS Burner.
Old 01-25-2013, 08:11 AM
In cold climates its usually a good idea to start your truck on stock when COLD... or a very low HP tune. But other wise i agree with ya Matt
Old 01-25-2013, 08:21 AM
Thanks Frank, I easily forget that I live somewhere that 80% of the rest of the nation doesn't get my weather. OP, Frank is right on wanting the lowest to no gain in HP for cold starts.
Old 01-25-2013, 08:53 AM
I'll keep all this in mind when I order will I get any smoke from any of the settings? Don't care if I do it not just wondering
Sent from my DROID RAZR HD while messing with my truck
Old 01-25-2013, 09:00 AM
Danger Will Robinson, DANGER! (Did I just age myself )
Hoyboy, you'll get smoke when you mash the skinny pedal but no one will burn a smoke setting. Our turbos are designed with mid to high RPM flow that on the low RPMs will smoke a bit. Not at cruising, you have to force it.
OK, lips zipped..
