5 to 6 spd - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-05-2006, 10:30 AM Thread Starter
5 to 6 spd
Hey Guys.
Anybody out there know if there is a 6spd manual that will replace a 5 spd manual? Would the swap be difficult? Is the overdrive ratio better on a six speed? I have already swapped my 4.10's for 3'55's but I need to get some more MPG. Thanks
96 F250 7.3
robotib is offline
post #2 of 8 Old 08-05-2006, 05:52 PM
7.3 tech, supporter
fordnut85's Avatar
I don't know how hared the swap would be since they are both ZF's I would think it wouldn't be too hard. On the 6spd's 5th and 6th are both overdrive and 6th is taller that 5th in a 5spd
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #3 of 8 Old 08-05-2006, 07:44 PM
scooby53's Avatar
Send a message via AIM to scooby53
if you ever figure out how to do that i would love to know i have a 97 f250 5 speed!!! when you changed your rear how many mpg's did yu get better? how much did it cost you fo the new rear?
scooby53 is offline
post #4 of 8 Old 08-05-2006, 08:06 PM
7.3 tech, supporter
fordnut85's Avatar
have you given any thought to the gear vendors under/overdrive?? Might be more cost effective than buying a ZF6
Duane
10k mod
Idle control mod
Tymar intake
post #5 of 8 Old 08-05-2006, 09:30 PM Thread Starter
I went from approx. 12 to 16 mpg. It was worth the bucks! The gears were right around $200, it's the bearings that will really set you back.
robotib is offline
post #6 of 8 Old 08-05-2006, 09:33 PM Thread Starter
I left out the fact that my truck is a 4x4. I wouldn't guess that an auxilary overdrive would work.
robotib is offline
post #7 of 8 Old 08-05-2006, 09:55 PM
overl0rd's Avatar
An auxillary overdrive unit would work, so long as you don't have the truck in 4 wheel drive with it engaged. The only problem is that the boxes become the weak link in the driveline, and if you tow a lot and/or do some spirited driving, you can expect to break it. As far as the tranny swap, anything is possible although I can forsee it being a big pain in the butt. I think the 6 speed is longer, so the tranny crossmember would have to be moved, and the driveshafts would have to be lengthened/shortened. I've thought about doing this swap in my truck, just haven't had the time or money to jump into it.
'96 F250 4x4 Ext Cab, 5 speed. K&N FIPK - modified to use 6637; 3" downpipe, 6" stack; Beans modded IDM; Beans stage 2s; shimmed FPR; exhaust brake; 6 position TS; locked 4.10s
'93 F250 4x4 regular cab long box. 7.3IDI nonturbo/E4OD 8' Western. STAYING STOCK
'65 Pontiac Tempest, 406ci chevy small block, TH350 with shift kit, 2700 stall converter.
'01 HD XL1200S - Lots of Screamin Eagle goodies
'96 Tbird LX V8
Progressive loves me
overl0rd is offline
post #8 of 8 Old 12-06-2006, 07:51 PM
jbawilliams's Avatar
I had a 96 with the 5 speed, and now an early 99 with the 6 speed. The OD ratio on the 5 speed was .77:1. The OD ratio on the 6 speed is .72:1. Not much difference. The low gears are nearly the same as well. The only thing the 6 speed gives you is more choices.
No trees were harmed in the sending of this message, however, a large number of electrons were terribly inconvenienced.
jbawilliams is offline
