Tie Rod Part numbers for 96 F250 Crew Cab
I have been searching online for tie rod part numbers and I am finding conflicting information. The passenger side tie rod end is shot. So I plan to replace that and the drivers side all at once.
I have read that Moog is good and the Napa Brand top of the line is actually a spicer built product. Whenever I look these products up, I find different part numbers, threads, sizes, etc... I was hoping to get a parts list and part numbers for all the tie rod components. The truck is a 96 f250 crew cab 4x4 with a 96 f350 solid axle swapped in. I assume the steering components are the same b/w the f250 and f350. I didnt do the swap so I dont know if the steering was changed or not. Last edited by PhillyB; 01-22-2013 at 03:53 PM. |
I am looking through this page at rockauto.com and the part numbers are different from what I have found on other sites.
96 1996 Ford F350 Tie Rod End - Steering - Moog, Front Left, Front Left Inner To Connecting Tie Rod, Front Left Inner To Pitman Arm, Front Left Outer, Front Right, Front Right Inner, Front Right Outer, Left - Pitman Arm to Connecting Tie Rod, Left - I believe I need parts: Moog DS1071 Front RT outer (which I believe is the passenger side joint and attached arm) Moog ES3009R Front LEFT OUTER (which I believe is the drivers side joint that attaches to the threaded end of the arm) Moog ES2012S Adjustable Sleeve I am confident about the front RT outer but would like confirmation that this is the correct LEFT outer.... can anyone confirm this is what I need? Last edited by PhillyB; 01-24-2013 at 05:35 AM. |
Just to followup... those are the correct moog part numbers for both the left and right outer tie rods on the f350 axle.
Just thought I would answer my own question in case someone searches it in the future. |
You want OEM?
E9TZ 3304-G
F2TZ 3304-B $291.31 FOR all 3! Let me know if you want them ordered Q259068 |
Do two of one number get ordered?
