Am I expecting too much (dump bed) - Ford Powerstroke Diesel Forum
Old 01-21-2013, 02:02 PM
Hello all. I have a 97 f-superduty. It has the utility sides with a dump bed. I will try to post some pics. I wasn't sure where to post my problem. Today was the first time I've loaded it down with anything. I got 3 tons of gravel and the dang thing wouldn't dump. I had to shovel quite a bit off and I shoveled the load more towards the back before it would dump. Is 3 tons way to much for these dump beds? It has an electric motor driving the hydraulics. Am I expecting to much? or could it be worn out? Any input will be greatly appreciated. Thanks
Old 01-21-2013, 02:28 PM
maybe look on the electri motor for any tags that mention max capacity???
just wingin' it here...
Old 01-21-2013, 02:39 PM
I will do that for sure. After shoveling gravel out of my DUMP truck, I was tired of looking at it. I just thought I would ask if 3 tons is out of the question.
Old 01-21-2013, 03:14 PM
6,000lbs YES, that is too much for it to lift
Old 01-21-2013, 04:31 PM
the baconator
depends on the pump and the electric motor driving it.
I will disagree with brad. our old 6.9 with a pto driven pump can dump 5 tons (10K lbs) of gravel
Old 01-21-2013, 05:04 PM
Thanks for the reply guys. The truck has 320k on it, so i'm sure the dump has seen a lot of use. Maybe its a weak pump, low fluid, or just worn out. Thanks for the reply so far
Old 01-21-2013, 05:17 PM
I would think 6,000 pounds would be fine. I would check out the hydraulics system.
Sent from my iPhone using AutoGuide.com Free App
Old 01-22-2013, 03:23 AM
PTO is quite a bit different than electric over hydraulic
Old 01-22-2013, 05:14 AM
the baconator
it's very true. i didn't know if you were saying that a dump ruck shouldn't be able to dump 3 tons. that is what i was disagreeing with. i haven't gotten our newest truck which is electric over hydraulic overloaded to the point of not dumping yet, but i will bet it is less weight than that old pto driven one
Old 01-22-2013, 05:18 AM
When I tried to raise the bed, all it did was squeal. Could that squeal mean a bad pump or just an overloaded pump? Thanks for all the input
