Fuel Pressure Question. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-17-2013, 07:31 AM Thread Starter
dajain's Avatar
She's a '95 OBS PSD.
Is there supposed to be fuel pressure when the motor is not running?
As soon as she quits cranking over or I shut her off. the pressure drops to zero. I would think the pressure would stay.
dajain is offline
post #2 of 5 Old 01-17-2013, 02:32 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
electric gauge or manual? the pressure slowly bleeds off, but if it is an electric gauge and you cut power the needle will drop.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 5 Old 01-17-2013, 04:11 PM Thread Starter
dajain's Avatar
I am using a oil filled gauge set up to hook to a schroeder valve. The oil filled is a little slower than anything else, but the pressure drop is instant.
With the gauge in place, there is no pressure. Start to crank the engine and it will climb to 50 - 60 PSI. Holds steady pressure while running. About the same pressure.
As soon as the engine stops, the pressure drops off. Immediately.
I didn't think this would be right, but not sure. This could be the cause of alot of my problems if this is not right.
dajain is offline
post #4 of 5 Old 01-19-2013, 11:12 PM
Ramsmoker's Avatar
Cool
I think what he is asking you is if the gauge is run from a electric sender or a hose hooked to the fuel filter. If it is inside the cab it better be sender controled. And yes, the pressure does bleed of in a short time.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #5 of 5 Old 01-20-2013, 04:55 AM Thread Starter
dajain's Avatar
It is a oil filled pressure gauge that gets threaded onto the shroeder valve on the filter housing. Nothing electric or any senders. All manual.
My bleed off is instant and that just doesn't seem right. There really isn't any bleed off to say, more like a drop off of pressure.
Of course I could be wrong, but instant doesn't seem right.
dajain is offline
