Dump bed - Ford Powerstroke Diesel Forum
Old 01-12-2013, 06:04 PM
Dump bed
Anyone ever install a dump bed on their obs, or dump flat bed? Any ideas where to look?
Thanks.
Old 01-13-2013, 11:45 AM
Look on CL. But just a FYI. Cab-n-chassis frames have 34" wide frame, pickups have 36" wide frames so you will be heavily modifying anything you find
Old 01-13-2013, 11:58 AM
thanks Brad, can you remind me which vin # is which?
Old 01-13-2013, 12:05 PM
Off topic but what are the tires on your truck and how well do they fit in there?
Craigslist. A lottle modification with a welder shouldn't be too bad depending on the setup of the dump bed. Hardest part will probly be the PTO setup to run the hydraulics
Old 01-13-2013, 12:16 PM
35's. Fit great, after a tiny shaving of the front bumper. I have a custom RSK that added inches or so and then 5 inch blocks in the rear.
Old 01-13-2013, 01:26 PM
Huh, they look bigger than 35s. They just seem to fill the wheel wells more than mine do.
Old 01-13-2013, 02:19 PM
my uncle had a gravel company and he had like a bed liner that was a dump bed. it was awesome and worked great. used a warn winch and pulleys under the bed liner and dumped.
Old 01-13-2013, 04:40 PM
Atvrider, here's a better pic.
Old 01-13-2013, 04:47 PM
I guess the RSK gave you just enough lift to make it look bigger. Looks good!
Old 01-14-2013, 01:14 PM
Have you thought about an insert dump body?
