Gauge Install - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 26 Old 01-10-2013, 08:11 AM Thread Starter
95Strokeee's Avatar
Gauge Install
Okay, I am doing 3 pods this weekend on my truck! I got boost, pyro, tranny. I have the ZF5 now, I know you guys will probably say that was a bad move, but oh well. I am planning on going E4OD soon. My questions are, what is the best spot to tee in the boost gauge? What is the best spot to tee in the pyrometer? And also, does the tranny probe have to be in the tranny fluid to be effective? I am planning on drilling at the PTO cover. Any help/suggestions are much appreciated!
Sent from my iPhone using AutoGuide.com Free App
95Strokeee is offline
post #2 of 26 Old 01-10-2013, 08:13 AM
Full A-Team Member
Fordman247365's Avatar
1. Intake spyder or MAP line
2. Driver side exhaust manifold on flat spot
3. No idea
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #3 of 26 Old 01-10-2013, 08:58 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Shane got this one. On the Tranny temp on the Manual maybe get an adapter and use the drain hole?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 26 Old 01-10-2013, 09:42 AM
superduty4x4's Avatar
How do you plan on drilling/tapping the PTO cover without losing a bunch of fluid and getting metal shaving inside your tranny? I'd just leave the tranny guage unhooked until you do the auto swap.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #5 of 26 Old 01-10-2013, 09:52 AM
Full A-Team Member
Not something I would mess with either but I assume take the cover off then refill with fluid
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #6 of 26 Old 01-10-2013, 10:09 AM
Undead Member
gaspipe's Avatar
Quoted: 6 Post(s)
x2. An unmolested ZF-5 is worth some cash.
~Bruce~
'95 F250 4x4 ECLB 296k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3/5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite exl trans filter, Autometer, 180w LED bar
gaspipe is offline
post #7 of 26 Old 01-10-2013, 10:28 AM Thread Starter
95Strokeee's Avatar
I understand. But does the probe have to be in the fluid to get a reading?
post #8 of 26 Old 01-10-2013, 10:34 AM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
You dont really need the Tranny temp on a manual. They dont heat up as bad as an auto
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #9 of 26 Old 01-10-2013, 10:34 AM
Quoted: 43 Post(s)
Yeah, tranny temp is pretty meaningless in a simple oil bath case. The ZF6 is pumped and cooled, so it might warrant a gauge. But +1 on leaving it decommissioned for the time being. At swap time, you'll be trying to sell a tranny with a useless hole in the PTO cover....
madpogue is offline
post #10 of 26 Old 01-10-2013, 10:37 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
To answer the question, yes the probe needs to be in the oil for the truest reading. The "air" inside of the case is not the same temp as the fluid.
Matt
'97
-Stage II trans.
BigFuel is offline
