The map lights in my truck quit working (all 4 of em). I replaced the light bulbs, and checked every darn fuse I could, and all seems well. I even took the light assembly off and apart to eliminate any "corrosion" issue. The cab lights work fine. And they all went out at the same time. I think I got a ticked off gremlin!!!!
really irritating me!
hmm.. no clue but here is a
Very odd!!! Could it be a relay?
So the lights won't come on with the door, switches on the light or the switch on the dash??
SO here is a pic.
The two outside lights dont work (map lights). But the middle one works as normal (dome light). Cant finger it out. Oh and I have two sets of these (crewcab). http://www.carcare.org/images/electr...rior_light.jpg |
Can you pull the light bulb and use a test light or volt meter to see if you have voltage to the socket?
I think you need to check the fuses again. Consult the owners manual for map light fuse location.
Time to tear it apart and start chasing for voltage.
Did you check the fuses under the hood? Dunno, maybe???????
NOt to highjack, but I have the same problem but it's with my cigarette ligher, and 12v power source. The fuse is good, but no power to those and now my cell phone goes dead constantly because its glued to my ear and I can't charge it in my truck.
