Need a parts list for e-fuel
Ok i know there are plenty of write ups but cant seem to find one with a complete parts list even down to the small fittings and hoses and fuel line parts. I finally have money rounded up and need a complete list part numbers is a plus but not necessary. I would like to do it the cheap way but whatever list i can get is better than nothing.
Thanks in advanced i know y'all will pull through for me |
there is no MASTER list. what pump do you wanna use? I used a brand new OEM 7.3 pump off of ebay. i wanted to be able to find a replacement part on the road at any parts store. what regulator do you want to use? I used an aeromotive one. you can also get a fuel lab one. what filters/bases do you want? i used two NAPA 4770 bases so i can find filters anywhere. for hoses i used high pressure high temp diesel rated hose from the local truck store. for fittings i used this
6404-12-08 | FEMALE BOSS x MALE PIPE ADAPTOR (if you call the shop above it is easier and cheaper than doing it through the website) to connect to the metal line behind the fuel pump. i adapted that to a 3/8 hose. for the regulator i took the regulator into the same shop and said i need to adapt this from -4 to fit it. they helped me out with fittings. i used a 5/16 line to go from the regulator back to the return line. i had to shorten the hard line on the return or fuel side, can't remember. I used a 7/8 freeze plug from NAPA to block the hole in the block |
I will make my own changes as for pump and regulator i really just need the fittings that are all used i am also wanting to use a sd pump and regulator will depend on whats left after everything else is purchased
