Brake fluid
I am looking to replace my brake fluid. Can I use DOT 4? Or do I absolutely have to use DOT 3?
Sent from my iPhone using AutoGuide.com Free App |
Basic difference between DOT 3 and DOT 4 are the minimum boiling points. Dry (freshly opened container) is 401* and 446*. Wet (having absorbed 3% water) 284* and 311*. Synthetic brake fluids resist boil-off and the effects of water contamination more effectively than conventional brake fluids.
So would DOT 4 have a higher boiling point? Is it okay to put DOT 4 in my hog? Thanks for the info
I'd only put what the book says. No reason to use DOT4.
I used DOT3 synthetic. |
Yes, a higher boiling point and I agree with jeslivas, synthetic DOT3 should be sufficient. If you tow heavy loads regularly DOT4 would offer more protection and I would think it would work with the Harley as well.
