rear drum brake - Ford Powerstroke Diesel Forum
Old 01-06-2013, 02:41 PM
rear drum brake
i had a leak coming from my rear drum brake so when i took it apart, aside from finding a couple springs broken i found this (pictured) piece hanging from a wire, not hooked up to anything. I checked the other tire to compare and the other one was just hanging there too. what is this suppose to be hooked up to?
and comes to my other question about my one broke brake, can i just buy the springs i need that broke?
Old 01-06-2013, 02:57 PM
Pic no workey. Hardware kits(the slings, clips and such are sold. they are about 15 per side
Passenger side brake assem
Old 01-06-2013, 03:15 PM
sorry guess it didnt work...lets try again
Old 01-06-2013, 03:47 PM
That cable has an EYE on one end. The eye goes at the top where the shoes pivot.. Then the cable wraps around a slider, then the end in your hand gets hooked on the adjuster bar
Old 01-07-2013, 03:17 PM
any idea what its purpose is?
Old 01-07-2013, 04:36 PM
It is part of the self adjuster
Old 01-15-2013, 02:00 PM
there are two hardware kits for the truck, one with 12" x 3" brakes and 12.12" x 3.5" brakes
how i know which one i have?
Old 01-15-2013, 02:55 PM
Is it a single rear wheel axle or dual? Dual rear wheel axle gets 3.5 and single gets 3
Old 01-15-2013, 03:25 PM
its a single, thank you!
Old 01-15-2013, 03:30 PM
Then you need the 12x3's only reason i know is i just rebuilt rear breakes and axles seals on my dually that has a single axle with spacers to make it a dually
