wanting to add three 2 inch amber leds to my psd - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-05-2013, 01:32 PM Thread Starter
I have a 1996 ford f350 psd that the guy before me added a lightning front bumper valance. I recently cut holes in the valance and added three 2 inch amber leds in the center of the valance. Looks really sharp. I want to wire these lights to come on with the parking lights. Is there a fuse in the fuse panel either under the hood or in the truck that I could use a fuse tap on. I tried the number 4 fuse inside the truck but the lights stay on all the time. I'm trying to get away from cutting into the original wiring harness. Thanks
nrpd diesel is offline
post #2 of 7 Old 01-05-2013, 02:07 PM
TRAXN's Avatar
Your fuses will either be hot all the time, become hot with the ignition on or engine running, depending on their purpose. You will have to tap into a wire on the parking light circuit after the switch in order to have them come on with your parking lights.
You won't hurt your harness by tapping into it, go fancy with it and solder it in with some heat shrink and loom. Good luck man
97' F250 RCLB 4x4 7.3 ZF5
192k miles
6637
S.S. 3" DP - 4" Straight Pipe
73' Bronco 4x4 302 C4 D20
TRAXN is offline
post #3 of 7 Old 01-05-2013, 03:44 PM Thread Starter
how do you remove the headlight switch from the dash, does anyone know what color the parking light wire is.
post #4 of 7 Old 01-05-2013, 04:37 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Traxn that is not entirely truer can lights are on a fuse tap for park lights and only come on with park lights just need to check with test light to be sure but it will work that way whether that's the right way or not is diff story I don't like it like that I just have more important things to fix right now
Sent from my iPhone using AutoGuide.com Free App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #5 of 7 Old 01-05-2013, 05:07 PM
jwatkins's Avatar
You can tap into the factory cab light plug that's behind the passenger side kick panel.
B] 97 ford f-350 Powerstroke[/B]
d-60, 02' zf-6 tranny, 6637,FPR Shim, Custom Dual 5" Exhaust and 3" dp, TS six position, Devils Own water/meth, DIY Exhaust brake, Pro-tech headache rack with Peterson LEDs, home made front and rear bumper, DIY leveling kit, SD steering column pod, Isspro EGT and Boost, Home made OHC.
jwatkins is offline
post #6 of 7 Old 01-05-2013, 06:56 PM
Quoted: 54 Post(s)
Um, it would be WAAAAY easier to just tee into one of the wires to one of the front parking lights. Shorter wire, one less punch through the firewall, and the headlight switch isn't the most fun thing to mess with.
madpogue is offline
post #7 of 7 Old 01-05-2013, 07:23 PM
kramarj's Avatar
^^Ditto
When I added lights to mine I had the same idea, and I got it out and pulled the knob out to the first position and there were like six hot wires and said screw that. I just went to the parking lights in the head lights.
My Truck
97' F-250HD. ECLB. 66,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
My Dad's
97' F-250HD. ECLB. 18x,xxx miles. 7.3. E40D. 6637 Filter. 4" Exhaust. TW Tunes. Work Truck.
97' F-250HD. ECLB. 150,000 miles. 7.3. E40D. 4" Exhaust. Work Truck.
kramarj is offline
