turbo - Ford Powerstroke Diesel Forum
Old 11-02-2007, 04:02 PM
turbo
is there any way i can get my turbo to spin/winde faster?? i want to go the cheap way. There is a guy my one buddy knows that when he get on the fuel it sound like a jet taking off, and its just the turbo. could i put a different spool in?? im just looking for ideas so i can get more boost and also make the turbo sound like the jet engine.
thanks
Old 11-02-2007, 04:05 PM
Desert Shield/Storm Vet
Bigger down pipe 3 inch. Straight pipe exhaust go to an open intake and a chip or tuner will add more fuel to the fire to spin your turbo. And don't forget the all important gauges to monitor your new found power I know its not cheap so start with a diy open intake
Old 11-02-2007, 04:26 PM
on my truck it is 4 inch exhaust with flow through muffler. also i have a tuner in it but i have no idea if it is even workin. every time i have it on and get on the fuel when the truck shifts from 2-3 the truck gets under the turbo and bogges out and turns on the "check engine" light.
Old 11-02-2007, 04:29 PM
Ahh your probobly defueling once you hit 23-24 psi of boost. You need a map fooler for your truck.
Old 11-03-2007, 08:17 AM
map fooler?????? i have no idea what that is.
Old 11-03-2007, 10:02 AM
Oh sorry about that. Its a mechanical or electrical devise that will fool your map sensor so it never sees the pre set boost for the pcm to defuel the engine. I have this one Overboost Annihilator
Old 11-03-2007, 01:36 PM
Install a .84 or 1.00 AR turbo exhaust housing. It will spoolup quicker.
Bill
