OIL leak Where dip stick goes in to pan - Ford Powerstroke Diesel Forum
Old 01-01-2013, 12:54 PM
Has anyone dealt with a oil leak where the dip stick goes in. There is a big nut that was looses so I tried to tighten it. It would tighten then go loose again. I am wondering if there is a easy fix for this. It always seems to leak there right after a oil change.
Old 01-01-2013, 01:31 PM
the baconator
diesel o rings makes a repair kit for about $50
Oil Level Gauge Adapter Repair Kit for 1994 - 2003
Old 01-01-2013, 01:38 PM
Sounds like it was over tightened and warped the inner piece. A new O-ring will do nothing if that is the case
