water leak
Well here is problem #2. I have a water leak that i have narrowed down to the top of the windshield (as i have water hosed it and the water drips in from there - and not the marker lights). So , i was quoted 135 to remove and replace (that is w/ new windshield if they break it and removing rust and priming it, if there is rust). Or can i just use some auto windshield sealant to seal it? if so, how is the outer trim around the windshield held on - i sure don't want to tear it off and find out i have more of a mess than i can fix myself
Thats cheap! I paid $230 with a discount for my 99 ranger to replace the windshield. If it was me and you have any corrosion then you need to grind it out it can be a bastage so have the professionals do it for you.
i had the same problem on my old truck and i just lifted the black rubber style trim and put some good pookie in there and smeared it around(cleaning it up as i came out to be visible) and just put tape over it for a day or so so the pookie can cure it sealed and vwalah no leaky
but its your windshield
oh yeah in case if your wanting to know what i used i used kitchen and bath clear silicone from lowes it was like $2.35 and it worked fine
mucho thanks.. i have some sealer so i will try and bust of the chrome trim and see what is underneath. does anyone know how that trim is held on? I would guess its just the sealant they used to seal the windshield.?
i tool off the trim and man it looks like 2 years of dirt and pine needles stuffed in there. some there is some surface rust around the valley the trip fits into and on the fasteners that connect the trim to the metal buttons attached to the cab. Should i put some naval jelly on those areas and then touch it up with some primer or just wash everything down and seal up the holes and see what happens - maybe take it in if it leaks again? Thanks
I reckon you have figured how the moulding comes off by now so I'll skip that. Naval Jelly may not stop the rust. Rust is Cancer and it will spread. If this place will truly fix the rust, by cutting it out and replacing the metal for the price you quited that seems really cheap and I would want to watch the repair. The only product I would trust to actually stop rust in POR15 or KBS. I prefer the KBS stuff. I am doing a frame off on a 77CJ5 and I am coating everything in KBS, it actually kills the rust and then seals it from the enviorment forever. Do just squirt selant in there and think you have cured the problem. It may stop the leak but it won't stop the rust.
Good Luck |
Rust is not bad on the metal. i did find that when they sealed it - they missed a few spots and i fixed that with some free flowing glass sealant. I am high and dry now. So we will see. Thanks all.
