Power window Relay??
Hey Fellas,
My passenger side window works intermittently. I replaced the window lift motor and checked the volts to the switch. I was wondering if there is a relay that could be bad. It seems like there could be a broken wire in the door. When the window fails to operate both the drivers side switch(that controls the passenger side window) and the passenger side switch don't work. Thanks for the help |
There's one relay for the system, so if it's the problem all your windows won't work. Check the wires from the pillar to the door (they like to break in between due to the constant bending). Cheers!
