help! 5 speed swap - Ford Powerstroke Diesel Forum
Old 12-28-2012, 02:28 PM
Exclamation help! 5 speed swap
doing a 5 speed swap and the southbend flywheel does not fit. bolt hole alignment is good but the flywheel doesnt fit the crank. im i missing something in the swap or did i get the wrong flywheel? part numbers show its for the correct truck.
Old 12-28-2012, 04:27 PM
need some opinions before i spend MORE money on this POS
Old 12-28-2012, 07:56 PM
I would suggest calling South Bend. I had issues with a flywheel and they figured it out before I could have. HTH.
