my first powerstroke input needed and welcomed
hello everyone as it states this is my first powerstroke i have always wanted one and when i got the chance to trade my gasser dodge for a 95 f-250 with 95xxx and little rust i jumped at the chance. now as i drive this truck every day i wanted to make it as reliable as possible so, i emiditly did a complete coolant flush and new water pump along with thermostat. i have also done glow plugs and injector harness along with fuel heater and filter. cps sensor has been changed. both battery's were cleaned tested and terminal ends were protected. i than cleaned all the grounds that i could possibly find and in doing so i found that one of the main ground cables to the block had been frayed and corroded all the way through so i made a new one.
now that i have done all the preventative maintenance i want to start making some more power and so far i have ordered a south bend clutch kit due to the factory clutch slipping and a 3" dp form mbrp. and now i have come to needing to ask what to do next what is a good direction to head in? for good power and reliability? any and all comments are fine and how have i done so far? |
![]() sounds like your on the right track when you cut the old dp out to put the 3inch one in make sure you push the pinch weld in for clearance and it would also be a good time to get rid of the kitty and muffler. then do an air intake most of us use a napa 6637 filter and get rid of the factory box. next comes gauges since you have a manual i would reckamend getting boost and egt |
And a big one is a chip go with custom tunes tho. Canned tunes u wont get ad much power and like the edge tuners are hard on automatic trans. I personally have an edge and i hate it.
the 140 v IDM mod
a oil crossover line to make it idle better and fire better
DFUSER Diesel Performance Products Exhaust High Performance Part Diesel Intake Diesel Power Chips |
do a tymar intake the wole kit from tymar for your truck is 110.00
509-922-8785 he is quite knolageable |
I was looking at going with a tony wildman 6 pos. And i am curently in the process of makeing my own intake out of a 4 inch peice of stainless and some silicone couplers and a large k&n filter. and i ordered the resistors for the 140v idm mod
Thankyou for the info. Keep it comeing |
You can also do the California fuel pressure regulator kit to bump your fuel pressure, but don't go over 70psi.
Don't use a k&n filter
