building up the truck and need info
im looking at putting in a set of stage 2 injectors and a 6 position chip and my truck is bone stock im going to also adding a 5 inch exhaust and my new front end d60 with rsk and pulling out the 4:10s and putting either 3:55 or 3:73s in i do pull a trailer every so often but mostly drive highway. i could really use the help cause i dont want to destroy my truck by building it wrong also black smoke is ok with me lol just want more power to keep up with them damn cummins that are all around me
Don't forget with them sticks you will need an upgraded hpop. Also I'd you tow I would stay with 4.10 gears or 3.73
im trying to build it on my own and how hard is it to replace the HPOP?
It is easy but you will also need to intercool it
were do i find the HPOP pump or should i just take it in to a diesel shop and have them do the pump and injectors? i can do the intercooler no prob. but injectors worry me a bit
Terminator Engineering for the HPOP-T500
Injectors are easy enough, just gotta take your time. 7.3's are extremely easy to work on |
You will want a turbo too
boy my wallet is gunna love me this spring lol what size turbo should i be looking at and what bout a lift pump i just replaced it with a stock one and with all im doing to the truck anyone have a clue what i should be looking at for hp numbers i got a stock clutch
i would go with a d66 turbo from beans
