Low Batteries in the winter
Agan, I have a 1996 F-350 PSD with auto tranny. In the winter or when it gets colder out my batteries seem tobe low when I go to start the truck. I know that batteries have a harder time in the cold keeping a charge. When its warm batteries hold a charge excellent. In the winter I always leave my block heater plugged in. Is there a way to tell if the block heater is working properly?
Your truck should heat up a lot faster than normal with the block heater plugged in. I would have your batteries tested though.
Along with the alternator. just to be safe. Take it by any Advance Auto Parts or NTB and they will test it for free.
Good Afternoon: I am a new user of the Powerstroke Forum. My question is this: Should I be using or is it necessary to be using a fuel additive to offset the low sulphur fuel. I have been told that this low sulphur fuel dries out the seals and hoses on diesel engines manufactured before the new low sulphur fuel came out. I have a 2003 F250 with the 7.3 engine.
In my opinion yes its a good idea. Not only the added lubricity but it ups the cetene value and helps clean the injectors. Also if you live in a cold climate get the anti-gel formulation.
truck had a new alternator last year and yes I have been told to run additive. I run lucas.
So did you get the batteries tested?
