Want more black smoke - Ford Powerstroke Diesel Forum
Old 10-31-2007, 08:48 AM
I have a 1996 F-350 PSD with auto tranny and with the edge programmer and I want more black smoke. I heard that you can get "smoker chips" to make them smoke good but have been unable to find them. If they do make these smoker chips can you stack it with another programmer. Is there any other way to make alot of smoke without getting to pricy. Any help would be appreciated.
Old 11-01-2007, 04:19 PM
I have a 97 with a flip chip and I only get a little bit of smoke. I can generate a decent amount if I really stomp the fuel pedal from a dead stop. I hear you can't do much better in an obs without new injectors. I guess I will have to live with what I have for now.....
Old 11-02-2007, 05:11 AM
Wouldnt that just be a waste of fuel making more smoke without making power. Really! why would you want more smoke if your only making a little over stock power? Does more smoke mean more power or is it just the aww factor your looking for.
Old 11-02-2007, 09:02 AM
i would say it would be the aww factor. I know that black smoke means unburnt fuel but I love the black smoke!
Old 11-02-2007, 10:42 AM
Oh ok, i see a truck running around northern VA sometimes and it smokes some kinda black smoke to the point you dont wanna be behind it. And it does make people wonder.
Old 11-04-2007, 10:46 PM
i was looking at tunes and i believe it was dp that i saw it on but it has a 140 horse position, and it said 140 horse smoke position so i would check them out but the only other way that i know of mainly is injectors.
good luck
Old 11-05-2007, 01:40 PM
7.3 tech, supporter
FYI the OBS trucks won't smoke like the superduties will, the factory injectors just don't spray enough to make BIG smoke. Do the right mods and the smoke will come lol
Old 11-05-2007, 05:21 PM
BIG TRUCK, SMALL DRIVER
You could run a 140 HP tune, but you will only see about a 70 hp gain, and little smoke, if any. If you have a good intake, clean air filter and good exhaust, you should not see any smoke unless you really get lug it. Like Duane said, You gotta get some bigger injectors for smoke. If you are on a budget, look a the DIY injector kits. I did mine for a little less than $400, and now I have plenty of smoke whenever I want it.
